950 PrePro/755 Pwr Amp
Discussion in 'Archived Threads 2001-2004' started by ChadLB, Jan 23, 2003.
  1. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Is this the best combo deal for < $2,100 or are there others to look at. If so where?
  2. Rick Guynn
    Rick Guynn Second Unit
    Mar 23, 1999
    473
    Have you done a search on this forum using the words outlaw 950? There are tons of posts that will likely help you.
    RG
  3. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    I have done some research but for the price it doesn't seem like there is much else out there for the combo and the price.
    Any thoughts.
  4. NickSP
    NickSP Supporting Actor
    May 8, 2001
    569
  5. John Tompkins
    John Tompkins Supporting Actor
    Aug 30, 2000
    660
    Acurus act-3 550 or so. upgraded by mondial to "stageone" status 950.00 that puts you at 1500 plus two parasound 855 amps for 10 channels of amplification 375.00 each, for a total of 2250.00...You can be creative and come up with LOTS of options if you want, if you are willing to buy used equipment..
    H/K AVR8000 1200.00 and nice two channel amp 400.00, total of 1600.00..
    Lexicon dc-2 1350.00 and 7 channels of amplification of your choice 750.00 total of 2100.00
  6. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    The key right now is a 5 channel amp probably at least 150 * 5.
  7. Bill Polley
    Bill Polley Second Unit
    Apr 18, 2002
    252
    Chad, besides the SVS, I also own an Outlaw 950. It is a great value. As far as amps are concerned, the 755 is a very good amp and a great value. I wonder, however, why you feel a need to have at least 150 X 5 power. do you still have the AR's?
    If you do, they are pretty efficient speakers. You can buy the power, but I am not sure you need it.The difference between 75 watts and 150 watts is only 3db, which isn't very much. If you were driving speakers with, say, an 87db efficiency, I could see where 150-200 watts would be needed. You could get by just fine with 100 X 5, or even a little less.
    I have a Parasound HCA-855a that I bought for under $500 brand new with a 10 yr warranty in Stevens Point (from a dealer). I believe Hi-Fi Heaven is a Parasound dealer also. It puts out an honest 85 X 5 (ALL channels driven) and has much more power than most receivers, which are usually rated with 1, 2, or 3 channels driven. Your powered sub will take a lot of strain out of the amp also. With the 950's ability to cross over at different frequencies, you can run your AR 11's from 40Hz up, cross over your 4C at 80Hz, and cross the 17's over at 60Hz. This will give you great imaging while taking the strain off the amp and allowing the SVS to effortlessly produce the deep stuff. (you did buy an SVS?)
  8. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    No I did not buy an svs yet. I am waiting....between the 25-31pci and the new box style.
    I asked the lady the other night wich one she thought looked better and her vote was for the box. The odd thing was last night at dinner she said so which one are you going to buy?
    I would still like to hear one.
  9. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
  10. Bill Polley
    Apr 18, 2002
    252
    It says MSRP is $2500. What can you get it for?
  11. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Probably about $900....not sure but I have a friend that works at Hi Fi Heaven. I went there yesterday and listened to the Blue Man Group DVDA.
    Setup was Mcintosh pre/pro
    Pioneer DVD 45a
    Legacy Speakers....the big daddies and a dual 12" sub
    WOW!!!!
  12. Bill Polley
    Apr 18, 2002
    252
    He should get you a deal on the Parasound. Great amp.
  13. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    For that price, I'd say it definetly is.
  14. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Yogi you are talking about the sonance..correct
  15. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
