Vince Maskeeper
- Jan 18, 1999
I have some really old 8mm films from my Grandmother's attic that I would like to restore as much as possible-- and have transfered to a digital format. My dream would be to find somewhere that could dump to 720p high-def-- but I think that my only chance might be a pro house- and we're talking mega mega bucks.
So, I'm leaning towards NTSC DV. It seems most places are using the same basic box to do the camptures, and 3 CCD XL-1s... which this seems like something I could do myself- and I'm really hoping for something much nicer. Heck I'd love to find a negative scanner that could automatically feed each frame and scan them super high resolution... but that is also unrealistic.
So my questions are as follows:
1) Has anyone dealt with any pro house doing 8mm dumps to DV they were SUPER happy with, and seemed to be more than a schmuck in a closet with an XL1? Is there any places that could do 8mm to high def masters at a non-astronomical rate? Is there any negative scanners that can do super 8 a frame at a time?
2) I would like to do a lot of the negative cleaning myself if possible. Are there any guides to 8mm cleaning/lube anywhere? I have done some 35mm still photo negative cleaning- and wondered if the same chemicals and tools are acceptible?
3) Is there anything I should look for in terms of services offered? It seems there is some debate on the best frame rates to dump 8mm film without roll and without serious speed up. I was under the impression that 8mm was designed for 15fps, so a 30fps telecine would be pretty easy to achieve.
Any help or discussion on this topic would be greatly appreciated. Maybe Robert Harris would take on my family memories as an important moment in cinema history and supervise a negative restoration and transfer.
-Vince
-Vince
