Jack Shappa
- Jan 24, 2003
Okay, I'm down to two receivers... The Pioneer 811s, and the Kenwood 6070. I decided I liked the 811s, plus it was a bit cheaper, so I bought it...
It sounds great, but the crossover choices are 100/150/200! I was hoping to set my crossover freq down to 80 (my speakers, some nice polks, should handle the midrange down to that point just fine I believe). The 6070 does 80/100/120...
One reason I like the Pioneer was the split rear channel outs for 7.1 surround sound... So now my questions are these:
1.) If I stick with the Pioneer, am I going to notice much difference between 80 and 100 crossover freq? Don't you start getting directional bass at over 80?
2.) If I go with the Kenwood, is simply using a Y-Splitter on the rear channel going to work as well as the Pioneer "pre-split" rear channel? Or does the Pioneer handle it in some more efficient manner?
3.) OR is there some other receiver in the $300-$500 price range that does all of the above better than the two that I'm interested in?
Thanks!
- JS
Thanks!
- JS
