Manuel
- Jun 29, 1999
I have a Dish 6000 receiver with the OTA cartridge. I have a Mits 65819 which will not accept 720p. My local ABC station is going to begin an HD(720p) broadcast soon. I have been told that my Dish 6000 receiver will upconvert a 720p signal to 1080i. My questions are:
-How does it look?
-How is the picture different after it is upconverted?
-How much different?
-Is there enough difference to find another solution to get HD?
-Which antenna would you guys recommend to use with the Dish 6000?
-Is it as simple as connecting the antenna and its ready to go?
-Anything else I need to know?
Your help is appreciated.
-How does it look?
