720p downconversion for OTA signals?
Chris_Campbell
Chris
I'm interested in picking up an ATSC tuner and antenna for OTA HDTV programming this coming fall (particularly my favorite show - Lost). However, it seems that ABC only broadcasts in 720p. Unfortunately my HDTV is older and only supports 480p or 1080i, will I be able to view the ABC programming in high def? Thanks.
Steve Berger
What brand and model of TV do you have? Many sets that don't support 720p natively will still scale it internally for display (like Sony).
Chris_Campbell
Chris
Mine is a Panny 47WX53. I bought it about 3 years ago. I'm not sure if it has a function to do what you say.
Thanks for the replies guys.
Jeff Gatie
Almost every tuner and most newer TV's will scale native 720p to 1080i. Check before you buy, but this usually is not a problem.
Chris_Campbell
Chris
Oh, so this is a function of the tuner? I was looking at the Samsung SIR-T451 tuner from refurbdepo. Anyone know off hand if this one will do upconversion to 1080i?
Jeff Gatie
It's actually a function of both/either.
Here's the manual for the tuner:
http://downloadcenter.samsung.com/co...F68-00335A.pdf
On page 12, there is a diagram of the layout of the back panel. #13 is "Resolution select". You would use this to choose the proper HD output.
Your TV manual is not online, so I don't know if it will also scale the 720p. But it really doesn't matter, the tuner will do it fine.
Philip Hamm
The signal is "degraded" because it's not presented in a native format.
Don't worry about that, it will look stunning.
Jeff Gatie
Not that I've ever noticed. The difference between 1080i and 720p is there, but it's not monumental. Plus, you really have no choice, most displays are either/or, not both, so you either scale it at the tuner or scale it at the TV.
muskantdramu
