RussellTodd
- May 17, 2004
I have question about 720 vs 480 progressive signals. I'm trying to calibrate my new Panasonic TH-42PWD7UY with a resolution 852 x 480 with the MOXI cable box. The cable box does not have an "override" function that recognizes the difference between HD and non HD sources. I like the aspect ratio the 480p setting gives me because it allows the Panny to do the stretching for me on non HD signals. However the HD images seem more crisp on 720p but then on the non HD channels the image appears poorly strecthed since the cable box is doing the stretching instead of the Panny.
My question is if the Panny only has a resolution of 852 x 480(EDTV) why does the HD image look better on 720p. Shouldn't 480p and 720p look the same since the TV can only display 480?
