Larry Marq
Grip
- Mar 30, 2003
I'd like to know if anybody has a 7.1 set up with the seating position up against the back wall. I have Klipsch RS3's as surrounds on the side walls facing each other about 3' above ear level. I was thinking of a more directional RB3 at ceiling level for the rears and either angled down or pointed almost straight down to the listening position. The room is 17' wide...Any ideas? I'm not sure if I'd gain much so close to the back wall. I might be able to convince the wife to pull the couch out a foot or so...Dolby reccomends them at the same height as the surrounds which would be pretty obtrusive.
Thanks, Larry
Thanks, Larry
