7.1 Speaker Packages
Discussion in 'Speakers' started by Nathan Rucker, Feb 16, 2004.
  1. Nathan Rucker
    Nathan Rucker Auditioning
    Feb 7, 2004
    8
    Does anyone have a 7.1 speaker set up? Are there any packages out there that you would recommend using with a Denon 3803 or 3805?
  2. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    You might want to post a general idea of a budget. Also include some guidelines such as "I want floorstanders all around" or "I want only bookshelf speakers", etc. You might also mention your usual tastes such as "warm" or "bright."
    There are many options out there and we can give suggestions, but as the canned response goes: "you have to listen for yourself."
  3. Jared Neumann
    Jared Neumann Stunt Coordinator
    Nov 11, 2003
    60
    I would reccomend getting matched speakers for your front three channels, di/bi pole for your side surrounds, and direct fire for your rear surrounds. There are many good 5.1 packages you can buy depending on your budget, then you can add 2 more for the rear surround.
    Jared
    My Theater
