7.1 seating?
Discussion in 'Speakers' started by Steve*_P, Sep 16, 2005.
  1. Steve*_P
    Steve*_P Agent
    Jan 18, 2005
    25
    My couch is against the back wall where the surround back speakers would be. Is it worth it to get 7.1 if the speakers would be right behind me or a little above. They would probably be about 4 ft. above people heads when they are sitting.
    Steve
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    They really reccomend pointing the speakers up in this situation in 6.1 / 7.1... It can be done.
  3. Charlie Campisi
    Charlie Campisi Screenwriter
    Aug 20, 2004
    1,620
    43
    1,610
    Where are your side surrounds? They are usually just opposite the ends of your seating or slightly behind the seating. No chance you can move the seating forward 3 feet?
  4. rob-h
    rob-h Second Unit
    Jul 6, 2005
    263
    Use multipolar speakers. Thats the best way to do it. If you must use direct radiators do as John suggests.
  5. Steve*_P
    Steve*_P Agent
    Jan 18, 2005
    25
    I cant move the seating up. Thanks for the reply's looks like they will be points up.
    steve
