7.1 - Our receivers have it - Will there ever Be 7.1?
Discussion in 'Archived Threads 2001-2004' started by David Flora, Jul 7, 2002.
  1. David Flora
    David Flora Stunt Coordinator
    May 26, 2002
    81
    I know many of us have 7.1 receivers, but will they ever make dvd's with 7.1 surround instead of just 6.1? I know you probably wouldn't hear much difference if an additional back channel was added, but if it's there, why not utilize it? Just seeing if anyone knows if there are any plans in the works to utilize it. Thanks!
  2. Alex Prosak
    Alex Prosak Supporting Actor
    Dec 9, 2001
    773
    This is a common misunderstanding. When a receiver manufacturer says 7.1, they mean they are providing 7 channels of amplification. In actuality, the two rear channels are mono and this is what the software in the receiver will allow for. If the people who make the movies ever produce a soundtrack that is actually 7.1 in terms of the channels, everyone would have to go buy a new receiver to decode it. So, I hope there isn't a 7.1 audio format in our future.
  3. Dave Vaughn
    Dave Vaughn Stunt Coordinator
    Oct 8, 2001
    186
    Hopefully those of us who bought an Onkyo 989 can just pay a couple hundred bucks for an upgrade and then have the 7.1 channels[​IMG]
  4. Kevin Alexander
    Kevin Alexander Screenwriter
    Apr 17, 1999
    1,357
    I'm capable of 7.1, but I highly doubt we'll ever see it.
  5. Steve Simm
    Steve Simm Stunt Coordinator
    Dec 26, 2000
    103
    I have often wondered about the value of 7.1 receivers over something like Yamaha uses in providing a single rear center channel. Is there a real advantage that anyone knows of in using 2 rears other than maybe for room symmetry in the placement of the rear speaker(s)? I haven't used a rear center but would think that a bipole speaker in that position would be adequate in spreading the sound around. Am I missing something?
  6. Steve K.H.
    Steve K.H. Supporting Actor
    Jan 11, 2002
    719
    Whether 6.1/7.1 the effective way to broaden the top (and rear) soundstage is to run two rear speakers. Simply run them in series in a 6.1 setup. This will dramatically change localization. The sides will blend around to the rear as opposed to a triangular dispersion.
    There are arguments for and against bipoles at the rear. Whatever the choice, I would not recommend a single bipole at the rear. (difficult to buy just one anyway)
  7. Marty Lockstead
    Marty Lockstead Second Unit
    Mar 4, 2002
    275
    I'm currently running a 6.1 system with a yamaha RX-V3200 receiver, 2 definitive tech. bipole rears and a single def tech center channel for my rear center. Even if I had 7.1 capability in my receiver, I wouldn't have enough room for 2 rear centers anyhow. As it is now, I think the rear center DOES make a difference, even if it isn't night-and-day over standard 5.1. According to THX-Ultra 2 specifications, one does require 2 rear center direct radiating speakers, while having 2 dipoles on the side. In my opinion, I'm glad that I have bipole rears over direct radiating as my left/right rear channels. Personally, I think it sounds better. But Steve is right, there are arguments on both sides of the bipole or no bipole issue. If I had the space for 2 rear centers, especially if dvds were to come encoded that way, I would jump on it. Bottom line:Whether you're adding 1 or 2 rear centers, it will sound better.[​IMG]
  8. Greg Haynes
    Greg Haynes Supporting Actor
    Oct 22, 1998
    577
    I just want more DTS 6.1 discrete soundtracks. It just seems like there is only a handful of titles that are actually 6.1 Discrete.
    Is it the studios that are not releasing the 6.1 discrete format or is that the movie was never recorded in 6.1 discrete?
  9. Marty Lockstead
    Mar 4, 2002
    275
    As far as I know, not many movies are encoded with EX/ES theatrically. I'm sure that will change in the near future, regardless, I would like to be up to date in terms of home theater technology.[​IMG]
  10. itai
    itai Stunt Coordinator
    Jan 23, 2002
    221
    "So, I hope there isn't a 7.1 audio format in our future.
    Alex, I hope you ment: in the near future!...[​IMG]
  11. Roger Dressler
    Roger Dressler Stunt Coordinator
    Jan 15, 1999
    187
  12. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    7.1 is really just an amplifier in my view. If you have 6.1, just buy a Y-RCA CABLE and split the pre-out rear surround to a stereo amp or pair of amps and there's your two rear center surrounds. It is often prefered compared to single rear center speaker anyways. Sometimes a single rear center speaker is hard to localize, so by putting two rear speakers there, you have the ability to localize the rear signal without having to move your head. 6.1 and 7.1 are the same in my view since the rear signal is in fact mono. One Y-cable and one channel of amplification are all that separate 6.1 from 7.1.
  13. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
  14. Greg Haynes
    Oct 22, 1998
    577
    Michael, thank for the info. Never knew that 6.1 discrete was for home use only. So I guess its up to DTS and not the studios to decide if they want to master the sound in 6.1 discrete.
  15. Willy burz
    Willy burz Stunt Coordinator
    Jun 7, 2002
    104
    Well I know it's not a gimmick in my opinion. If you were to listen to the DTS ES or Dolby EX dvd's on a 7.1 system(both rears play the same signal) you wouldn'g be talking about gimmicks. I personally and many others can hear a much better expierience than the 5.1 counterparts. I'll take Se7en, Gladiator, RushHour 2, The Haunting, T2, and the Phantom Menace over any 5.1 setup. More are coming out it's just a matter of time!
    Give me all the DTS ES and Dolby EX ya got, cause it is superior to a 5.1 setup!
  16. Michael Reuben
    Feb 12, 1998
    21,763
    2
  17. ricky ho
    ricky ho Stunt Coordinator
    Apr 7, 2002
    55
    10
    hopefully i wouldn't have to buy a new receiver if a 7.1 format ever comes out. i would have to buy a multi-channel decoder(if it's made and not to expensive). my receiver (denon 3802) has ext.in and pre-outs for 7.1. so when buying this receiver i felt i was basically covered for a 7.1 upgrade path.
  18. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    There won't be a 7.1 dvd digital audio standard until there is a new dvd (part of hd-dvd?) digital audio standard. The existing standards (DD/DTS) were not designed to support 7.1 discrete channels and can't support it. This will mean you'll need both a new dvd player (in order to read it) and a new processor in order to decode the new standard.
    cheers,
    --tom
  19. Greg Haynes
    Oct 22, 1998
    577
    I believe THX was talking about a 10.2 system not too long ago.
    I couldn't imagine fitting 10 speakers and 2 subs in a single room. That's alot of speaker wire [​IMG]
  20. Matt Jesty
    Matt Jesty Second Unit
    May 15, 2002
    390
    I hope that no one is begging to upgrade again, because I doubt if many/any of the "software-only" upgradeable units set-up the audio paths to take advantage of the possibility.....
