7.1/6.1 reciever output question
Discussion in 'Beginners, General Questions' started by JohanD, Apr 26, 2004.
  1. JohanD
    JohanD Stunt Coordinator
    May 22, 2003
    180
    Take for example two recievers:
    100w x 6 channels @8ohm (6.1)
    100w x 7 channels @8ohm (7.1)
    Lets say I only have a 6.1 setup. If I have 6 speakers hooked up to the 7.1 receiver, what happens to the power of the 7th channel? IE does the amplifier share the load across channels, or is that effectively "lost"?
    6 speakers on the 6.1 will get 100w each (theoretically), what do 6 speakers on the 7.1 get?
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Hard to predict, but most likely neither will be putting out nearly that much power into all the channels at the same time. Don't get so tied up with the wattage numbers so much.
  3. JohanD
    May 22, 2003
    180
    Right.. I understand that.. but I just mean what would put out more.. then 6.1 or 7.1?
  4. ChrisWiggles
    Aug 19, 2002
    4,791
    it's impossible to predict, unless those are concrete numbers, which I'm sure they are not at all. Without knowing the receiver, it's really going blindly by numbers, that I'm sure you pulled from the product specs, which mean absolutely nothing without the clarifying informatiion of how they were derived.
    What receivers are you looking at specifically? That would elicit far more useful help than these numbers, which really mean nothing. At best they indicate that one receiver has 7 amps, and the other only 6. But that's about it.
  5. JohanD
    May 22, 2003
    180
    I wasn't looking at any receivers specifically. I just meant everything else being equal if there was a difference between output of a 6.1 and a 7.1 receiver. Did not pull the specs anywhere except from theoretical argument. [​IMG]
  6. ChrisWiggles
    Aug 19, 2002
    4,791
    Well, theoretically speaker, if those specs were fully accurate, that all channels in each could put out 100W full-range continuously, then that would seem to indicate it is the amp stages that are the limits of output, not the power supply, as is normally the case, so then they should function as specd. PRetty unhelpful, though, IMO, theoretically speaking, since the power supply is almost always the limiting factor.
