6ohm speakers on a 8ohm/4ohm receiver
Discussion in 'Archived Threads 2001-2004' started by allan espinoza, Jul 24, 2002.
  1. allan espinoza
    allan espinoza Stunt Coordinator
    Jul 1, 2002
    210
    i have a yamaha receiver with a 8ohm/4ohm switch for the mains and 8ohm/6ohm for rears now my question is, is it possible to use 6ohm speakers for the mains or will my speakers get damaged or receiver? if so what should i switch it to?
  2. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    What are the speakers?
    Generally 6 Ohm speakers can be run at the 8 Ohm setting. Try it...listen for distortion at higher levels and watch for heat build up from the receiver. If you detect problems put the switch to 4 Ohm.
    Without an Ohm vs Frequency graph it is difficult for people to visualize that oftentimes a speaker's impedance rating is given for a momentary dip into that territory at a specific frequency.
  3. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
