Marc_F
- Jan 29, 2000
I have my 2109 DVD player (still haven't pulled the trigger on progressive scan) hooked up to my 65H80 using component cables to the HD2 inputs. I have the DVD player settings set to a 16:9 picture size. Now if the TV picture size is set to "Normal" then the picture is a squished 4:3 shape with grey bars on the sides. The picture looks correct when the TV is set to "Theater Wide".
Is this the correct way to be viewing my DVDs? I would think since the DVD player is set for 16:9 then the TV would be set to normal, but that isnt the case unless I am doing something completely wrong.
Just need to know if I've set it up correctly.
Thanks in advance,
Marc
Thanks in advance,
Marc
