64 = 65 ?
Discussion in 'Archived Threads 2001-2004' started by Sam Davatchi, Feb 22, 2003.
  1. Sam Davatchi
    Sam Davatchi Producer
    Sep 15, 1999
    3,150
    [​IMG]
    I got this by email and have not spent much time on it for the sake of my sanity. So the question is please someone why o why 65 = 64? I don’t want to turn crazy! There must be a trick but I don’t see it! [​IMG]
  2. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,788
    498
    9,110
    It's an optical illusion. The pieces don't fit perfectly, and that's where the "extra" square comes from.
  3. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Patrick is righ, it is an optical illusion.
    Ignore the illusion and do this:
    Forget about the whole shape they make, it is an illusion, its not a proper fit. If you examine the edges you'll see mismatching.
    Calculate the areas of the geometric shapes individually in each case and you end up like this:
    Out of the orange and blue polygons, make the biggest rectangles you can and you are left with two smaller triangles. Now calculate the area for all the shapes and add them all up. It doesn't matter which shapes. Even if you calculate the area for the shapes in the new "false" shape, its still 64.
    It doesn't matter what you do. 1/2 base x height for the triangles and length x width for the rectangles for all the shapes = a total area of 64.
    The two big triangles=12 blocks each x 2 = 24
    The two small triangles=5 blocks each x 2 = 10
    The two rectangles are 15 each x 2 = 30
    24 + 10 + 30 = 64
    So there you go [​IMG]
  4. Wayne Bundrick
    Wayne Bundrick Cinematographer
    May 17, 1999
    2,358
    Yup, it's not exactly 5 x 13, it's 4.944 x 12.944 or a similar slight deviation such that it still multiplies to 64.
  5. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    I've seen a similar one done just with triangles. One way I found the problem with that one was to examine the slopes of the triangles. I found they weren't equal. Thus I was able to figure out the fact that the shapes weren't perfect triangles.
    I think the trick works partly based on the thickness of the grid lines and the thickness of the dividing lines. Those have to be taken into account, and when you look at this, you kind of look past those.
  6. Leila Dougan
    Leila Dougan Screenwriter
    Mar 27, 2002
    1,352
    The diagonal line in the new shape is thinner at the upper right and thicker at the lower left. If you watch the shapes as they move around, the thickness of the surrouned lines change thickness.
  7. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
    i am convinced that 64 = 65
    [​IMG]
  8. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,475
    340
    9,110
    Cees Alons
    This is a very old problem. Fun to see it come up again.
    Actually, there's a (very long and very thin) diamond shaped space in the center of the second image. It's a "hole" in the whole surface and its own surface is (you guessed it) exactly 1 square. So, because it's not part of the second shape, after subtracting that 65 - 1 = 64 again.
    Cees
  9. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Thats why if you ignore their trickery you can just assume that the lines they put on the shapes should go from point to point, meaning, from the corners of those squares and then do the math of the area geometry. Length x Width and 1/2 Base x Height will do you fine each time.
  10. Kevin T
    Kevin T Screenwriter
    Jul 12, 2001
    1,402
    i'm convinced that 25 = 18 [​IMG]
    kevin t
  11. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,644
    777
    9,110
    Ha! Makes me think of my old Calculus class in college where the professor would get a kick out of confusing freshmen by "proving" to them via some real convoluted formula that 1=0. He offered extra credit to the class to prove him wrong and no one could do it (he wrote the whole thing out on the chalkboard and I've since discarded all my notes from that class).
  12. RobertR
    RobertR Lead Actor
    Dec 19, 1998
    9,963
    350
    9,110
  13. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    There is a book you folks should read. Its called:
    Zero. Biography of a Dangerous Idea.
    by Charles Seife
    Its neat. Most of you would find it interesting [​IMG]
  14. Leila Dougan
    Mar 27, 2002
    1,352
    Chris, I have not read that book but I have read "The Nothing That Is: A Natural History of Zero". Ironically I just looked it up at Amazon and noticed it was double-listed with Zero.
    Quite fascinating, I might add. I recommend it to everyone who's even slightly fascinated with math.
