6 ohm speakers
Discussion in 'Archived Threads 2001-2004' started by Trent_N, Dec 1, 2002.
  1. Trent_N
    Trent_N Agent
    Nov 8, 2002
    46
    Newbie question:
    My front speakers are 6 ohm speakers (Yamaha) and my surrounds are 8 ohm (Sony bookshelf). My receiver is a Sony STRDE-945 which is rated at 5x100. My receiver seems to handle the 6 ohm speakers without a hitch.
    Is this a problem? Is my audio experience diminished because of this?
    Thanks.
  2. Jeremy Stockwell
    Jeremy Stockwell Supporting Actor
    Aug 9, 2001
    608
    Trent,
    That's the setup I have right now with a Kenwood (VR-509) receiver. Shouldn't be a problem.
    You might check to make sure your receiver isn't getting hot, though. You might need to get a cooling fan if the receiver is enclosed in anything (like an closed entertainment center, etc.).
    JKS
  3. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    The lower the impedence (ohms) the harder the speaker pulls power from the receiver. Most HT speakers and receivers are based on 8 ohms. In reality, impedance varys continusously. You speakers are probably only pulling 16 or 8 ohs at normal levels. At peak times it could pull as low as 2 ohms. So, you should be fine. The only problem with running at a lower impedeance is heat. As long as the receiver does not get super hot, you are fine.
  4. Trent_N
    Trent_N Agent
    Nov 8, 2002
    46
    Thanks guys, you've been a big help.
