6 ohm or not to 6 ohm this is my question
Discussion in 'Archived Threads 2001-2004' started by David D. C., Jan 6, 2002.
  1. David D. C.
    David D. C. Stunt Coordinator
    Dec 30, 2001
    71
    this area is cool idea
    what prices are 6 ohm speakers ????? i need some info on the pros and cons of 6 ohms and 8 ohms
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Don't worry about ohms, as the actual value seen by the speaker is continuously variable based on frequency.
    Do you know of any speakers that are specifically designed as nominal 6ohm? I don't remember hearing of any.
  3. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    I wonder if some amp mfr's use the 6 ohm readings for marketing purposes only.....
    [​IMG]
  4. DwightK
    DwightK Second Unit
    Sep 12, 2000
    269
    The Phase Tech PC-1 I have is a 6 ohm rated speaker. Have no clue why as it works well with my other 8 ohm phase techs. Goofy.
  5. Mike Mitrook
    Mike Mitrook Agent
    Dec 14, 2001
    35
    Many MB Quart home speakers are 6 ohm. In their case it seems the more large drivers the model has (like dual 6.5s) the lower the impedence (down to 4 ohm). I don't know why this is versus their two way sets.
    Mike
  6. Derrick G
    Derrick G Stunt Coordinator
    Jun 4, 2001
    52
    Vienna Acoustics are rated 6 ohms nominal.
    Derrick G
  7. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,145
    I gave my son 3 RVS Energy speakers which are all 6 ohm running on a 1105 Yamaha. No probs.
