6" id pvc port, where?
Discussion in 'Home Theater Projects' started by Dave Crigna, Jan 3, 2004.
  1. Dave Crigna
    Dave Crigna Stunt Coordinator
    Dec 8, 2001
    132
    Hey guys,
    I live in the los angeles area and need to know where I can find 6" (by 25" length) diameter pvc tubing to make a port. L have checked the big stores hd and lowes and a few other places and the biggest they carry is 4" id. Any suggestions would be great.
    If I can not get 6" tubing, would dual 4" x 21" be an ok substitute? Modeling shows about 3-4ms more air speed in port @20 hrtz compared to the 6" X 25".
    This is for a strke av15 in a 8cf enclosure with @ 500rms into it.
    Thank you in advance[​IMG]
  2. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    Did you try looking in the waste pipe section of the stores? Also, try Mcmaster
  3. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    Have you considered using 6" ID sonotube for the port. It is fairly common and availabe at HD, Lowes etc.
  4. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,717
    463
    I got mine at a Plumbing Supply store (for contractors and plumbers, not really a general public store) that I found in the Yellow Pages. Unfortunately, I had to buy a long section of it, of which I still have over 6 feet of it, I think.
  5. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    The Lowe's in my area carry the green PVC drain pipe. You have to ask for it since it's not out in a big bin
  6. Dave Crigna
    Dec 8, 2001
    132
    Actually this is for my friends sub enclosure. I will pass along all the great info. Thanks again[​IMG]
    Also isn't there a rule of thumb to go by, if a port is x in diameter, you do not want to go longer than y length? I thought it was 5x. Is this correct?
