6 divas 2.1 ????
Discussion in 'Archived Threads 2001-2004' started by gene avallon, Mar 2, 2002.
  1. gene avallon
    gene avallon Stunt Coordinator
    Jun 13, 2001
    187
    when I get my new outlaw stuff im going to dump all the old stuff ar 1 from a very long time ago and shack sarounds. I have 2 46plus with 1000 amp.I never listen to music unless its on a action dvd.does that make a difference? so I was thinking of six 2.1s and there center channel they should be matched that way.will I be missing anything getting rid of those aucoust research AR 1s they gotta be 20 years old.so guys get me going in the right direction.
    gene [​IMG] [​IMG]
  2. PomingF
    PomingF Second Unit
    Mar 4, 2000
    343
    I don't recall too many Diva users with an all 2.1 set-up but you may want to head over to AVSForum which has most Diva info and post the same question. I recall one guy replacing his M&K's with 5 Diva M1's (the one with the ribbon tweeter).
    PF
  3. gene avallon
    Jun 13, 2001
    187
    ok lets put it this way,im going to replace all my speakers I need some ideas,the divas was one proably dumb.so any body give me some ideas.just HT no music
    gene [​IMG] [​IMG]
  4. Sean D
    Sean D Stunt Coordinator
    Sep 3, 2001
    181
    Hi Gene,
    I don't think that the 2.1 setup all the way around is a stupid idea at all. I think they should be fine when used together with a decent sub. I have no experience with your old speakers so I can't say anything about them. The Divas sure are nice looking speakers and from everything I've read about them I'm sure you will be happy with the sound. I have a Diva setup coming this week and I can't wait.
    Best of luck,
    Sean
  5. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    What is your budget for 5 (or 6) speakers? What is your associated equipment? Any major placement restrictions?
  6. gene avallon
    Jun 13, 2001
    187
    BOB
    whatever 6 diva and a center diva cost.the outlaw 770and 950 are comming.I have twin 46+ with 1000amp this was the first up grade.remember I dont care about music I never listen to it as I asked before does that make a big difference? the room is about 10x15,lots a stuff on side walls not good for dipoles? 56 inch tv up front on ten foot wall 2 foot space on right side left side flush with a door to landury room,alwaws open.sweet spot about 6 feet in frount of tv.sourrounds just above ear level even with sweet spot,back wall ok for two more speakers.when I put a floor speaker on the left side the back of it is open to the laundry,you have to squeze by.hope this is enough info.
    gene[​IMG] [​IMG]
  7. Bob_A
    Jul 30, 2000
    876
    gene, I think identical bookshelf speakers all around would give you a fantastic setup. As for what manufacturer to choose, that is a tough call. At www.cheaphometheater.com they did a shootout between Diva 2.1, nOrh 4.0, and a couple others. Good luck!
  8. Steve Zimmerman
    Steve Zimmerman Second Unit
    Dec 6, 2001
    347
    Gene, do I understand correctly that you don't have room on the side walls? If I'm mistaken then you should consider something like the Diva R3s as part of the mix. My personal recommendation would be a pair of 4.1s and a C3 up front, a couple of R3s on the sides (if you have room) and a pair of 2.1s directly behind. If you don't have room on the sides then just skip the R3s.
    Oh and if you go the Diva route, make sure you talk to one of the guys at AV123.com about a package deal. They'll take care of you.
    Unofficial Diva FAQ
    --Steve
  9. Steve Stogel
    Steve Stogel Supporting Actor
    Jul 19, 2000
    600
    I'm also curious as to how six 2.1s would work. I was leaning towards the nOrh 4.0s all around, but the Divas have been very well received. I'm still leaning nOrh's way, but the Divas are better looking, IMO. I still like the nOrh's appearance (especially all black ceramic), but the Diva's grabbed my attention asthetically. Seems they are similar in performance, but the Divas are a bit more cash.
    The question I have concerns the Diva center. $500?! Ouch, babe. It also has the MTM design that some people so vehemently say to avoid. That's why I was thinking a 2.1 as a center (not mentioning saving the cash) might be a better idea. So why is it that I don't hear much criticism of this particular MTM center? Shoot, the Cheaphometheater shootout had 2.1s as mains, the center, and the R3 rears. That means the mains were the cheapest of all the speakers. Seems a bit odd to me. If you can find any of my questions in this post, feel free to give an opinion. Otherwise, sorry about the length.
    Steve
  10. Steve Zimmerman
    Dec 6, 2001
    347
    Steve, the C3 center sure sounds good to my ears compared to the Cerwin Vega center I had before [​IMG]
    If you're interested in the C3, you should call AV123.com to see what sort of package pricing you can get. It won't cost you $500 when purchased as part of a package. In fact, if purchased with a pair each of the 4.1s and 2.1s, the C3 is free. (see web site for details yadda yadda)
    --Steve
