6 channel in
Discussion in 'Archived Threads 2001-2004' started by Don Harris, Aug 29, 2001.
  1. Don Harris
    Don Harris Auditioning
    Aug 19, 2001
    5
    OK why is this, when I hooked up my DVD Audio to my receiver and I play a DTS music CD. When I use the 6 channel in, the volume is really low, and when I use the optical in it's a lot louder? Yes, both have DTS decoders on board.
    Thank you in advance,
    Don
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    You probably have to adjust the input level of the 6 channel input, I know my receiver has a variable level for that input.
    Check the manual for your receiver- if it doesn't have an adjust for the input, check the output on the player and see if it has a level adjust.
    -Vince
    http://www.musicianassist.com
    AIM: VinceMaskeeper
    Interested in moving into FRONT PROJECTION with huge 6-10 foot widescreen? Buy my whole HDTV-ready CRT based front projection system delivered, cheap! Click here
  3. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Also if you've got your speakers set to "small" you're probably losing a lot of bass on the 5.1 channel input. Most recievers do bass redirection in the digital domain and therefore it's not active for the 5.1 channel input.
    Philip Hamm
    Pat's the best!™
    AIM: PhilBiker
    click on the little green house to see the evolution of my home theater!
