bert halter
- Oct 27, 2004
I have a denon 3802 I will be using as a preamp and using klipsch reference fronts, center and surrounds. I want to add additional amps to the preouts. Would a 6 channel amp sound as good as using 3 seperate 2 channel amps all rated at 200 watts per channel. or would they be identical just using one unit instead of 3 units.
The option I am deciding between are the Aragon 2005 5or 6 channel amp rated at 200 watts /channel or using 3 separate B&K refence 2channel amps 200.2 reference
I will be using the system for both home theater and home audio
