6 ch. input
Discussion in 'Archived Threads 2001-2004' started by AbelM, Dec 30, 2001.
  1. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    What is it? I have it...but what do I use it for...why is it differ? [​IMG] [​IMG]
  2. Dan_Jones
    Dan_Jones Stunt Coordinator
    Dec 1, 2001
    120
    You could use it for DVD Audio or a DVD player that has a built in decoder....
  3. David D. C.
    David D. C. Stunt Coordinator
    Dec 30, 2001
    71
    this is correct sir
    6 ch is set up for a nice dvd player that has all your outputs front center surround and sub is this a technics reciever???? plug them into the reciever for your sound
  4. Charles J P
    Charles J P Cinematographer
    Aug 19, 2000
    2,049
    2
    Omaha, NE
    CJ Paul
    Most higher end receivers have 6 channel inputs, even if they already do have Dolby Digital and DTS decoders in them. This is for DVD-Audio and multi channel SACD. Its because no digital output has been set for the formats, so the decoding is done in the player and then sent to the receiver as an analog signal instead of digital bitstream.
  5. AbelM
    AbelM Second Unit
    Dec 28, 2001
    374
    Hmmm, so which would be better a coax out or the 6 ch?
  6. Andrew V
    Andrew V Stunt Coordinator
    May 11, 2000
    197
    I would say that a Digital Connection would be better. This is because the decoder in the Receiver is better than the decoder in the DVD Player.
  7. BruceD
    BruceD Screenwriter
    Apr 12, 1999
    1,220
    I'm a bit confused!
    Your first post said 5.1 (6 channel) receiver input, your last post says coax (digital?) or 5.1 (6 channel) output.
    Which one are we talking about?
    As before the receiver's 6ch input is connected to the 6ch output from a DVD-A player, SACD player, or even an ICBM (bass management unit) sitting between the receiver and DVD-A or SACD player.
    The receiver's 6Ch output can be connected to an external 5 channel amp (bypassing the receiver's own amplifiers) and a powered sub. This is useful when speakers need more powerful amps then those provided in the receiver.
    BruceD
