6.1 vs 7.1
Discussion in 'Archived Threads 2001-2004' started by BrianRS, Jul 29, 2001.
  1. BrianRS
    BrianRS Stunt Coordinator
    Jun 18, 2001
    57
    Can someone explain the difference between these two. What modes support these set-ups, what is the proper speaker set-up, and is there a real advantage to going 7.1 vs 6.1?
    Also, since very little actually comes through the rear speaker/s(I think), could you get away with a inferior speaker/s for the back?
  2. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    There are no official 7.1 formats for the home theater environment. There is only one 6.1 format, DTS-ES.
    Surround-EX is derived information, meaning it isn't actually encoded into the data.
    The choice of one or two rear speakers is left up to the user.
    DTS-ES discrete contains a 6th channel which is once again monophonic, but can be played back on one or two rear speakers.
    John Kotches
    Contributing Writer
    Secrets of Home Theater and High Fidelity
  3. Hubert
    Hubert Second Unit
    Mar 9, 2001
    424
    Actually, DTS claims that DTS ES 6.1 has a discrete center rear channel, and I've always thought of it as the only discrete 6.1 format.
  4. John Kotches
    Mar 14, 2000
    2,635
    Hubert,
    Maybe I'm missing something here... let me double check.
    Nope. I definitely mentioned DTS-ES discrete.
    John Kotches
    Contributing Writer
  5. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
    It frustrates me to hear 7.1 refer as a 6.1 with using two rear centers, its not 6.1 with two centers. There are 7.1 DSP processing put out by several different companies. What they do is take a 5.1 info and create two new side channels by combining the Front Left and the Rear Left/Front Right and Rear Right and placing it to the sides of the main viewing and placing the original R/L surrounds in the rear.
    Dolby and DTS has a new surround encoding and decoding called EX/ES and is "refer" to as 6.1 which can run the same amount of speakers as a 7.1 system by running two Rear center speakers. But the new two rear center speakers are receiving a mono signal.
    Dolby's EX and DTS ES new Matrixed channel is extracted out of the Surround Right and Left channels, and placed in the rear of the main seating with the Surround L/R on the sides of the main seating.
    DTS has also taken 6.1 to a new and true level by actually encoding a discrete ES channel on to some of their ES recordings that make it the only true 6.1.
    Wes
  6. TomH
    TomH Second Unit
    Jun 13, 2001
    267
    So,theoretically,
    If a receiver has 7.1 pre-outs and is SW upgradeable it should be able to support any new 7.1 format including the rumored overhead channel. ??
    Tom
  7. John Kotches
    Mar 14, 2000
    2,635
    Wes,
    I don't consider any derived channels as being a "real" format - they are estimates on what might have been in the channels. Nothing more, nothing less.
    As such, the only "real" 7.1 out there would be Sony's SDDS in theaters. Although it is officially in the DVD-Video spec as an alternative audio format, it is not scheduled for home theater release.
    Just my opinion, it sounds like we don't agree.
    Not the end of the world, and good healthy discussion is worthwhile.
    John Kotches
    Contributing Writer
  8. Wes
    Wes Screenwriter
    Sep 30, 1997
    1,190
    Utah USA
    Wes Peterson
  9. Hubert
    Hubert Second Unit
    Mar 9, 2001
    424
    John, I misread your post. When you said the center surround was monophonic, I was thinking you were saying that it was derived from the left and right surround, hence it wasn't discrete. My bad.
