6.1 Receiver with 5 Speakers
Discussion in 'Archived Threads 2001-2004' started by wally, Dec 10, 2001.
  1. wally
    wally Second Unit
    Feb 12, 2001
    473
    Can you run a 6.1 receiver with only 5 speakers (plus sub) leaving the center rear empty?
    I'm thinking about using a leapfrog type upgrade path and replacing my aging DPL Sony receiver with the Denon 2802. I purchased a Polk system several years ago, but can't afford to make the jump with receiver and full 6.1 speaker upgrades at the same time. If I'm planning on making this receiver purchase last 4-5 years, what are the benefits of biting the bullet and going with the 3802?
    Thanks!
  2. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    Sure it will work, a good set of speakers and good location will create a phantom rear channel and place sounds to where there could be a rear center channel.
  3. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    My SR-6200 allows you to turn off the rear center if you do not have one. I would think the Denon might allow the same thing. For ES material the rear center sound is redirected to to the other two and gives a similar effect, but is not nearly the same as actually having the speaker(s) there. Yes it will work fine.
  4. Mike Witt
    Mike Witt Stunt Coordinator
    Aug 10, 1999
    142
    Yes, the 2802 allows you to set the rear center to none, one, or two speakers. I just bought one and spent the weekend setting it up. I only have 5.1 speakers currently and it sounds great.
  5. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,213
    Absolutely. Affirmative. Sure thing. Without a doubt.
    (Does any of that constitute a yes? [​IMG])
