6.1 Receiver Suggestions...Budget Concerns
Discussion in 'Archived Threads 2001-2004' started by Matt Stone, Mar 2, 2002.
  1. Matt Stone
    Matt Stone Lead Actor
    Jun 21, 2000
    9,063
    Right now my setup is based around a Sony DB840 which I bought about 1.5 years ago. As it turns out, my parents (I'm a college student living in an apartment) are setting up their first HT and they want to buy my reciever off of me...allowing me to get a new one. I'm looking for something in the ~600 range. I'll probably wait to buy something until May-June, so if there is something on the horizon...I could take suggestions there too.
    I would do the leg work myself, but I really don't have the time now...and you guys helped me decided on the DB840 (which I have nothing but good things to say about), so I figured I'd just throw the question out there. Anyway, thanks all for the help!
  2. Matt Stone
    Jun 21, 2000
    9,063
    Jeez...I completely left out what I'm looking for. Definitely 6.1, and a plus would be component vid switching. The speakers used with this will be the Energy Take 5, and prolly another Take 1 for the rear center. If I've left out somethin (which is definitely possible) just tell me. thx...
  3. Andrew_Ballew
    Andrew_Ballew Second Unit
    Feb 21, 2002
    294
  4. Sankar
    Sankar Second Unit
    Aug 1, 1999
    315
    You should see some good used receivers (like the Denon 3801, etc) hitting the market soon after the 950 arrives. Since you can wait till May or so, that may be a way to go. With a budget of $600 these should all be within your grasp.
  5. Matt Stone
    Jun 21, 2000
    9,063
    Kewl...could you send me a link with specs for the Denon?
    As for the rear center...then are there two outs for the rear center?
  6. Matthew_Judd
    Matthew_Judd Extra
    Jul 14, 2001
    24
    You may also want to consider the upcoming Onkyo 600 receiver that will retail for $530 and should be out by the time you are looking to buy. I am also looking into receivers in this price range and this is one of the ones on my list (I am also looking at Denon).
  7. Sankar
    Sankar Second Unit
    Aug 1, 1999
    315
    Check out Denon's site .. then go to "Home Audio", "Products", "Discontinued Products Archive" .. this should take you to this place hopefully .. you will find the 3801 there. The 3801 is similar to the 3802, but does not have DPLII.
  8. Matt Stone
    Jun 21, 2000
    9,063
    Thx!
    Could someone provide a little more info on the 7.1 issue. Is this all about using two speakers for the rear center rather than one center channel? I'm sorry if I sound like a newbie...[​IMG]
