6.1 question
Discussion in 'Archived Threads 2001-2004' started by david*mt, Dec 18, 2002.
  1. david*mt
    david*mt Second Unit
    Dec 11, 2002
    306
    Does the 6th speaker in a 6.1 set up have to be a center channel speaker? For example, if I am using two Klipsch bookshelfs as my rears can I just add another one of them in between the other two to complete my 6.1 system? Will this sound alright? I wasn't sure if it had to be a center channel or not.
  2. Wayne McRae
    Wayne McRae Stunt Coordinator
    Dec 28, 2000
    234
    It does not have to be a center channel. 1 direct rad. will work just fine.
  3. Cire
    Cire Stunt Coordinator
    Aug 20, 2002
    67
  4. BrentPollard
    BrentPollard Second Unit
    Dec 18, 2001
    445
    Generally speaking you want all speakers to be identical. So adding another Klipsch would work well. You wold be ready for 7.1 as well because you would have to buy a pair.[​IMG]
  5. EricSm
    EricSm Stunt Coordinator
    Aug 29, 2002
    109
    My main problem is where to put the extra 6th channel. Our couch is flush with the wall. The l&r rears are mounted high, to the side. I just have these images of me banging my head against the speaker repeatedly when I go to lean back... or my wife asking what that unsightly thing is hanging off our back wall... Pulling our couch out isn't much of an option, unfortunately.
  6. EricSm
    Aug 29, 2002
    109
    While we are on the subject, let me ask a question---
    what it be less than ideal to put the two additional rear speakers off to the sides of the couch on the two end tables I have... facing the TV of course? I could do that with little to no problem, aside from needing to come up with some speaker wire.
    my setup would then look something like this:
    Sub L C R
    < ^ Couch ^ >
    Is that just dumb? : )
  7. BrentPollard
    Dec 18, 2001
    445
    For the 6.1 or 7.1 effect to work you must have your 6th & 7th speakers between your surrounds. In your case mounting the 6th speaker dead center maybe 3 or 4 feet above your head. If you can move your couch out even 1 foot from the wall then you place your surrounds also up about 3 feet above ear level when seated.[​IMG]
  8. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
