6.1 Amplifier to Center Back Speaker Question
Discussion in 'Archived Threads 2001-2004' started by Alex Dydula, Jan 5, 2003.
  1. Alex Dydula
    Alex Dydula Stunt Coordinator
    Nov 1, 2002
    170
    Hello,
    I am thinking of installing one Dahlquist QX20R rear back speaker, mounted i the center of the rear wall in my listenting room.
    My receiver is a SONY ES STRDA4ES and is 7.1 capable.
    How do you connect the rear "6.1" back speaker to the amp section??
    There are two amp outputs one for back left and one for back right....do you just pick one because the information in EX/ES is tha same for both???
    Thanks in advance!
    Alex
    Raleigh, N.C.
  2. BrentPollard
    BrentPollard Second Unit
    Dec 18, 2001
    445
    Yes I think you just pick 1 then in your receiver menu select 1 rear center.[​IMG]
  3. Michael Langdon
    Michael Langdon Stunt Coordinator
    Aug 29, 1998
    110
    Many receivers and processors default to or suggest using the left output when using only one center back speaker. My owners manual for my processor states to use the left output for one surround back or center back speaker. Check your owners manual (if you already haven't) to be sure.
  4. Alex Dydula
    Nov 1, 2002
    170
    Marc, from the Audioshop in Ottawa, Canada replied to a email I sent him, he actually called SONY and they said to use the left channel amp out with one speaker for 6.1 center.
    Thanks!
    Alex
