6.1/7.1 worth if couch on back wall?? (1 Viewer)
Rob Dawn
I'm going to be building a new house in the next year and will have the family room pre-wired for speakers.
We'll have walls on either side of the couch so the standard surround speakers will be easy to set-up - either on stands or attached to the wall.
But the couch will sit right on the back wall so I'm wondering if rear surround speakers would even be worth it since they would be directly over our heads??
What are your thoughts or experiences all...
Rob
Stephen Hopkins
If you're pre-wirring, I would considering wirring for 7.1. As for actually impleminting it, it's a wash. If your side surrounds are wall mounted fairly high, you could wall mount the back surrounds at the same height. If your side surrounds are on stands, you could always pull the couch a foot or 2 off the wall and have the back surrounds on stands too. Either way, your current receiver doesn't support 6.1/7.1 and your webpage mentioned your next upgrade being speakers, which is probably a wise move.
So yeah i'd wire for 7.1, but I wouldn't run out and upgrade your receiver right away to impliment it. Just keep your options open for the future.
brentl
I'd consider using a single dipole on the center of the rear wall, and 2 surrounds one on each wall!
Brent
Kevin Thompson
Have you considered in-wall speakers? I've never done this, myself, but if you're building a new house from the ground up, it might be a good solution for you. I'm sure there are people on here with experience and advice on in-wall speaker installations.
Righ
