John Tompkins
- Aug 30, 2000
I have the lex mc-1 and calibrated the side speakers using internal tones on the lex. I then calibrated using avia and the sides were 5db lower using avia versues using the lexs internal tones ?
I turned off the BACK speakers to use avia as you cant calibrate the BACK speakers but only the side speakers. The funny thing is, when I turned the BACK two speakers on and ran the avia test tones on the sides, the calibration was the exact same as the lexs internal test tones. Keep in mind though, doing it this way avia playes tones from both the side and the back speakers at the same time, be it the left or right. Does the lex maybe take this into consideration and lower the sides internal tones by 5 db ? PLEASE HELP...thanks
