57HX81 and replacing gray PIP bars with black
Discussion in 'Archived Threads 2001-2004' started by Michael De Costa, Nov 4, 2001.
  1. Michael De Costa
    Michael De Costa Stunt Coordinator
    May 8, 2001
    156
    I have been trying to replace the gray bars in the picture in picture mode with black ones and have yet to do so. I know I was told that this is an option the TV can perform but I have yet to figure it out. Then manual has no such option. Can this be done? If so, how? Thanks
    At my signal, unleash Hell.......
    Toshiba 57HX81
    Denon 3802
    Panasonic RP-91
    Toshiba 808 6-Head SVHS
    Definitive 2002TL's Mains
    Definitive CLR2002 Center
    Definitive BPX2 Surrounds
    DirectTV
  2. Michael De Costa
    May 8, 2001
    156
    anyone....Buhler......
  3. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    Michael, I think this may be possible in the SERVICE menu (USE CAUTION). Unfortunately I can't help you there but someone should be able to. If you don't get an answer here try over at the Spot
    Luke
    [Edited last by Luke_Y on November 05, 2001 at 09:26 PM]
  4. Cameron Seaman
    Cameron Seaman Supporting Actor
    Apr 26, 1998
    708
    I don't think it can be done on this year's or even last year's models.
    You had to access either designer or ADDR menu (I can't remember which) and it's unknown how to get into this menu on the newer sets. It's possible, but supposedly kept quiet because it's alot easier to ruin your set with these menus.
    [​IMG]
    The HTF Lowest Post Champion!
  5. Andrew Beacom
    Andrew Beacom Supporting Actor
    Jan 11, 2001
    792
    If Toshiba haven't blocked it on the new models you can use a special remote to gain access to the ADDR menu. Then in theory you could experiment to see what control the grey bar settings.
    A bit risky though unless you know exactly what and where to change.
  6. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    Do you realize that doing this (if you could) will speed up the phosphor burn-in problem?
    John Golitsis
    Next Big Thing Electronics
