Mikey_K
- Aug 11, 2002
I have a quickie question for you guys. I will be ordering a convergence template, however I've got a question regarding the 56-point convergence for my 50h81. Great set, first off -- absolutely wonderful television. I've been perusing these boards for a couple weeks now and have been mustering the courage to attempt the 56-pointer. My question is this: if I screw up during the process, can I turn the set off without hitting 7 on the remote, turn the set back on, and start from scratch? I've read this is true. Please confirm this, ANYBODY?
Also, I've noticed that the geometry is off just a tad. For instance, the top edge of movies with a 1.85:1 ratio isn't perfectly straight. If I, with a template, straighten out the green lines during the convergence and realign the red and blue to green, will this "problem" disappear?
Thanks for the help, gang.
