dizzyrapper18
- Nov 23, 2012
- ryan
So I bought these speakers for my first step in my first home theater system. Not sure of room size yet as I'm going to be moving within a month or 2. I know a little bit on what to look for in an AVR but still not comfortable yet. What are some Major must haves in AVRs to be great.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290210
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290200
Heres the receivers on newegg and when I search I look at the most reviews and top rated. Do I even need a 7.1(2) since i have 5 speakers an am not sure i will need 7 since im not moved into a new house yet and would assume the room will be small enough for 5.1, so that should be good? Can I get some options from You about what You think would be a good fit for the speakers I recently bought?? Doesn't have to be with newegg but I've bought everything else from there. I would be greatly appreciated with what you guys suggest.
http://www.newegg.com/Receivers/SubCategory/ID-488?Order=REVIEWS
was looking into pioneer elites but heard if you dont buy from like best buy the warranty will not work.
