Jean D
- Mar 8, 2004
- Jean D
Hey all, about 2 years ago I bought a 55" HD Widescreen Mitsubishi rear projection for about $3000. At the time I didn't know about DVI. My tv doesn't have it unfortunately. If I had waited about 6 months, I probably would've made sure it had it. (It has 3 component, only one of which will do 1080i and the other two will only do 480p, and none will do 720 - strange huh?) I was however, wondering if anyone knew how expensive, if possible at all it would be to have my tv upgraded to include a DVI input. or should I just wait a few years and just hold out for a better one? I'm assuming that I should go with plan B, but I just wanted to know if anyone had a similar issue with their tv (finding out after-the-fact)or knew if it is possible and feasible to do it.
