51" Widescreen or 53" Big Screen
Discussion in 'Archived Threads 2001-2004' started by Tony Cicirello, Nov 5, 2001.
  1. Tony Cicirello
    Dec 28, 1999
    23
    I'm interested in either 51"16:9 or 53"4:3.
    My primary purpose is for DVD and sports (Soccer)
    Which would you go with and why?
    Sony 51"Wide or 53" Big screen
    Tony
  2. Phil Iturralde
    Phil Iturralde Screenwriter
    Oct 7, 1998
    1,867
  3. Cameron Seaman
    Cameron Seaman Supporting Actor
    Apr 26, 1998
    708
    Personally? I'd pick 16:9 hands down.
    [​IMG]
    The HTF Lowest Post Champion!
  4. Richard Kim
    Richard Kim Producer
    Jan 29, 2001
    4,385
    Say, Phil, where did you get the Toshiba at that price?
  5. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Phil,
    Thanks for that CGI bases 4:3 vs. 16:9 aspect ratio calculation
    tool!
    On a 61 inch 4:3 TV
    16:9 (1.78:1) letterbox mode
    Your viewing area is 48.8 in(w) x 27.4 in(h)
    The diagonal size is 56.0 in
    Total viewing area is 1337.12 sq in.
    This is the equivalent of a 56.0 inch 16:9 TV
    Your viewing area is decreased by 25.1% from 4:3 mode
    Way cool! [​IMG]
    If DVD's are a primary source and you are an avid OAR'r
    (Original Aspect Ratio) then I would say get the BIGGEST
    16:9 you can afford. If your going to be primarily watching
    Over The Air Broadcasting which is 99.9% presented in a 4:3
    Format then get the BIGGEST 4:3 you can afford.. Either way
    you should get the biggest that you can afford and fit into
    your surroundings [​IMG]
    [​IMG]
    Brett DiMichele
    My Home Theater Site!
    [email protected]
  6. Phil Iturralde
    Oct 7, 1998
    1,867
