$500 for reciever AND speakers!!!! help :)
Discussion in 'Speakers' started by Anthony_Gomez, Oct 6, 2003.
  1. Ok, my uncle has a HARD limit of $500 (he'd like to spend as little as he has too if you know what I mean..so $500 is bleeding his wallet).
    I'd build him something (speakers), but I just don't have the time anymore.
    He wants them on the small size (Energy Take 5's are acceptable in terms of size).
    Being able to buy at a B&M is a plus, but I don't think it is a requirement.
    Any suggestions would be GREATLY appreciated.
    PLEASE DO NOT suggest saving up more money for "X" package. $500 including tax and shipping (if applicable) is a HARD limit.
  2. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    Acoustic Research HC6, 5.1 speaker package can be found online for just a little over $300. this leaves a little under $200 for a receiver. There are a number that can be found in this price range.
  3. Kenny_H
    Kenny_H Stunt Coordinator
    Jul 5, 2001
    122
    For what it's worth, a few more details would help. Such as: do you just want a pair or a complate 5.1 speakers system & a reciever, or do you want a complete Home Theater in a Box system, room size, etc??? If it's a HTB system, check out the SAMSUNG HT-DB600 system (www.samsungusa.com slim line, 5-disc DVD/CD/CD-R/RW, JPEG, progressive scan,reciever w/ component out, DPLII)all for ($299.00)! Playing back CHICAGO in DTS & LOTRII in DD didn't sound bad! I know, not an Energy system, but, my 2cents worth.
  4. My uncle already has a DVD player so that isn't a problem. HTIAB or separates is fine.
    He is looking for a 5.1 system. The room is about 14x20 if my memery serves me right. They will not be cranking it like I will with my system.
    I know there are many options so that is why I am trying to draw on the experience of others on which ones to look at (and conversely, stay away from). In this budget category, I'm sure you can find as much good stuff as garbage.
  5. Danny Tse
    Danny Tse Producer
    Nov 1, 2000
    3,185
    Denon 483 receiver (same as the 1403) receiver brand new from Denon-authorized dealer 6th Ave Electronics $150.00 including shipping.
    Add the AR HC6 speaker system and you wil have an excellent sounding system. And under $500.00.
    I really should work for "Trading Spaces".
  6. Bill_Wil
    Bill_Wil Stunt Coordinator
    May 26, 2003
    165
  7. Nhan_H
    Nhan_H Second Unit
    Feb 6, 2003
    431
    Skip all the HTiB stuff and go with what Lew and Danny suggested. The HC6 alone is worth more than the $500 HTiB systems. The sound and build quality of the HC6 speakers vs. HTiB speakers is not even a fair comparison.
  8. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Considering the hard $$ budget and the fact they will not be playing it a ear bleeding levels, Danny has got the right rig I belive.
    I've listened to the exact set up Danny mentions and was floored at how good it actualy sounded. In that size room at lower to med volumes, it should make them very happy in all respects.
    Very nice set up, and makes the budget to boot.
    May be other stuff (speakers/receivers/or package deals) out their to look into, but these products are certainly proven performers that can be had cheap, perform great, and are attractive to boot...
    Regards
    Geoff
  9. Steve Adams
    Steve Adams Second Unit
    Oct 20, 2001
    432
    check out fluance.com for speakers. they have a complete system with 2 towers, 2 bookshelf and a center for 199. they sound great for the money, and then take the other money, go on ebay, pull off a 5 channel pioneer vsx receiver and you have a great system. don't let the price fool you, the fluance speakers are darn good speakers for sound and value....
  10. THanks! I'll be looking into those.
  11. Steve Adams
    Oct 20, 2001
    432
    you wont be sorry. the sx htb is the better sounding system but the 199 system is pretty good too. you wont be sorry...
  12. Jason Hammerly
    Jason Hammerly Supporting Actor
    Oct 28, 1999
    739
    I'm selling a nice little set of Velodyne CHT. There's a nice review in the listing. I could maybe go a bit lower to to give you some more room for the receiver and a cheap sub.
  13. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    I second the AR HC6 speaker set, very good for the money.
    Another suggestion could be to get
    JBL NSP1II 5-Piece Home-Cinema Speaker Package $209
    Sony SA-WM500 150 Watt Active Subwoofer $135
    And for the reciever, you could check,
    Panasonic SA-HE100K Home Theater Receiver $220
    Pioneer VSX-D812K A/V Receiver $230
    Pioneer VSX-D712K Audio/Video Receiver $175
    Plus shipping, I know you said you needed inside $500 range with shipping, but this extra bucks will give you a big improvement oven any HTiB or even the HC6, but this is only my opinion.
    And if you decide to go with a HTiB, check
    Kenwood HTB-505 $399
    Kenwood HTB-506 $499
    Onkyo HT-S760 $499
    Good luck with your choice.
    Pablo
  14. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
  15. Joseph R. Zodda
    Joseph R. Zodda Auditioning
    Sep 20, 2003
    3
    I recommend the Fluance Speakers also. They sound great and are very reaonably priced. I have them paired with a Kenwood VR-6060 receiver from ecost for $99..its a refurb but works like a charm. (The Denon mentioned is nice also. If you add the nice Dayton Sub that has been mentioned in this thread you have a nice system for under $500
  16. Chris Bates
    Chris Bates Stunt Coordinator
    Nov 28, 2001
    74
    Where did you see $15 for shipping?......The page I looked at said $101.00....OUCH!
  17. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    I got the system for your uncle! It's actually the exact system I'm recommending my friend to get.
    JBL NSP1 II
    $180 from buy.com
    Dayton 100w 10" powered sub
    $125 from partsexpress.com
    Onkyo TSXR500 Factory Renewed (this does include 1 yr warranty)
    $150 from onecall.com
    $455 plus shipping and maybe tax from some of those places.
    Or go with the Denon receiver that Danny Tse recommended if you don't want factory renewed.
  18. Stephen Hopkins
    Jul 19, 2002
    2,598
    Hmm, they had shipping listed as $15 when i first posted, no clue why it jumped up to $101. Give J&R a call and see if they have any un-advertised promotions on shipping or if there's any way that can get the shipping cost down to something reasonable.
  19. Greg Thomas
    Greg Thomas Second Unit
    May 3, 1999
    438
    I like Richard H recommendation the best.
    JBL NSP1 II
    $180 from buy.com
    In addition to the Onkyo TXSR500 or Denon 483 you can also look at the HK AVR 125 for $180 factory renewed from an authorized retailer.
    Total $485 plus shipping.
    or if you want to go HTIB the Onkyo 660 is $400 including shipping here
  20. DavidLM
    DavidLM Agent
    Oct 1, 2003
    28
    Here's the Onkyo HT-S760 refurbished for $299 + $15 shipping. For $300 you could put some money elsewhere, such as DVDs, a rack, cables, beer, etc.
    Wow thats a great deal. 1 year warranty too.
