$500 for "real" setup or klipsch promedia ultras...
Discussion in 'Speakers' started by Brandon[C], Oct 30, 2003.
  1. Brandon[C]
    Brandon[C] Auditioning
    Oct 19, 2003
    5
    I have $500 to spend on audio gear, but heres the catch, $200 of that is best buy credit. I have been considering getting a set of the Klipsch Promedia 5.1 ultras (this wil be used with my PC)- can I do better with a "real" home theater setup for the same price? It will be used for everything, alot of music and gaming, and occasional movies in a 10x10 room. I really like the sound of klipsch speakers, so I'd prefer to go with klipsch or something with a similar bright rock-and-roll sound. The system doesnt have to be 5.1, 2.1 or 2.0 is fine for now as long as it has excellent overall quality.
    Your expertise will be appreciated. thanks ^_^
  2. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    Well in my opinion the ProMedia's are a good choice but you can do better. Take a look at the Klipsch Quintet's from bestbuy, add in a sub and you got yourself a nice Home Theater system.
    When you look at the Quintets you will be amazed how the ProMedia's look somewhat like them. The Quintet's are a bit bigger, and quite heavier as they don't use a plastic case like the ProMedia's to save some costs.
    Klipsch makes a quality products and it's great speakers. If you can't afford the Quintets then go for the ProMedia's, they are a very nice system as well, especially the new Ultra.
  3. DanielGM
    DanielGM Stunt Coordinator
    Jul 15, 2003
    116
    Buy a decent set of loudspeakers and a decent stereo receiver. Surround is overrated for music. Look into either used speakers or a used receiver in order to get the best quality under your price point.
