5.1 speaker system recommendation for VSX-527-K (1 Viewer)
mhmt
mhmt lcn
Hi,
I decided to buy VSX-527-K receiver and need some ideas about speakers. I want 5.1 system.
Room is 20sqm (5m*4m). I don't need so loud ones.
I don't want to spent more than the receiver (VSX-527-K).
These are some options:
- Canton Movie 90 5.1 System
- Pioneer S-ES3BT 5.1 System
- Yamaha NS-PB150 5.1 System
- Magnat Interior 5001A 5.1 System
Any other ideas? recommendations?
Thank you!
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
Where are you finding the Canton where it costs less than a VSX527?
Otherwise, pick the Magnat over the other two.
Being so tiny none of them are going to crossover any lower than 120hz, but Magnat will probably be the most even sounding.
mhmt
mhmt lcn
Thank you for the reply!
Canton Movie 90 5.1 System is 230 EUR. and I pay 270 EUR to VSX-527-K.
I guess you recomment 1st Canton Movie 90 and 2nd Magnat. Do you have any other recommendations other than these 4 option at this price range?
Chris_Wilson3
