5.1 Speaker Package....$300 budget
Discussion in 'Speakers' started by John Doh, Jun 7, 2004.
  1. John Doh
    John Doh Stunt Coordinator
    Jun 24, 2003
    199
    Can someone recommend a 5.1 speaker package (can be separated by satelittes and sub if need be) that can be had for $300 or less? The front and surround channels need to be compact in size to be discretely mounted in the ceiling corners of the room. Also, the 5 speakers must either be white in color (preference) or silver (second preference). The sub can be black if need be. Thanks!
  2. Brad_See
    Brad_See Stunt Coordinator
    Apr 25, 2004
    178
    One possibility:
    http://shop4.outpost.com/product/3821437
    Not the greatest but with your limitations, especially colors, I don't know of many great options.
    Is this to meet a wife's restrtictions? If so have you presented her with the idea of a good-looking woodgrain? That would open up your options considerably.
    brad cook
  3. Greg-ST
    Greg-ST Stunt Coordinator
    Jan 27, 2003
    193
    You can try to find the JBL NSP1II speaker package (usually sells for around $200 or so... speakers are black, but have silver highlights when the grills are off). For the sub you can go with the 10" Dayton 100 watt powered subwoofer from Parts Express (http://www.partsexpress.com/pe/pshow...=300-632&DID=7)
  4. Cam McFarland
    Cam McFarland Supporting Actor
    Feb 6, 2004
    699
    If you dont have the receiver yet, you could get one
    of the Onkyo HTIB in silver for right at $300-350.00
    including the sub.......
    Just a thought, & work better than you think
    if you are on that kind of budget.....[​IMG]
  5. Daman
    Daman Second Unit
    Feb 4, 2004
    402
    2 more choices- Polk RM6005- 300$ with a free PSW 202 Sub- BUT IS BLACK and Cambridge Soundworks package(dont remember the model number)- 350$ with sub- comes in white and black ,sub is black
  6. Alan Wise
    Alan Wise Stunt Coordinator
    Jan 28, 2004
    236
    John,
    I'll second the reccomendation for the Polk6005 system with the sub woofer. It's tough to beat for $ 300.00.
    Also, if it were me, I would concentrate on getting the best sounding set up for my $ 300.00, and not get hung up on the color.
    Find what sounds the best, even if it's black, pink, or plaid. A can of silver (or white) spray paint, and some elbow grease is all you need.
    Good Luck, Al. Wise
  7. John Doh
    Jun 24, 2003
    199
    Daman,
    Where can I find the Polk package offering a free sub?? Thanks!
  8. Robert V
    Robert V Stunt Coordinator
    Feb 26, 2001
    79
    Buy.com has the JBL N24II speaker pairs for $79 shipped. Pick up 3 pairs for 240. Each pair includes mounting brackets. Pick up a dayton sub at parts express or get a cheap sony sub or a yamaha sub.
  9. Joe Szott
    Joe Szott Screenwriter
    Feb 22, 2002
    1,962
