5.1 - 6.1 - 7.1.......Is it worth
Discussion in 'Archived Threads 2001-2004' started by Brad Newton, Jun 26, 2002.
  1. Brad Newton
    Brad Newton Second Unit
    Aug 14, 2001
    382
    the additional cost? Can the "average joe" really hear the difference with an "average" system? I'm sure that the hig end audiophiles will say that it is worth it? But is it really........What about THX??????? Does the same hold true with it?
  2. Charles Bunnag
    Aug 18, 2001
    19
    Im assuming from your topic you are running a pro-logic system. In that case I would say that upgrading to 5.1 is big difference. Directionality, Sound Stage and Ambience are all improved. Though I dont have much experience with 6.1 and 7.1, I think you can do without it. The difference isnt as big as the change from pro-logic to 5.1. As for THX, I wouldnt worry about that anymore. When things first started out, THX did make a difference. Now every major company is out there to make good products so they dont bother going through THX certification. As long as it sounds good is what really matters.
    P.S. Im not ragging on THX. I dont have any THX components, but I still appreciate their work
  3. Gerard Martin
    Gerard Martin Second Unit
    May 22, 2000
    366
    Agree a 5.1 is a must after that 6.1 and
    7.1 are nice too but not necessarily have
    too options. I have one of each and don,t
    hear any real difference between the 3
    unless of course your setup is in a room
    so large the 1 or 2 back surrounds are a
    must also. Many will say PLII common on 6.1 and 7.1 is the greatest thing since sliced bread, its nice but again have too,
    maybe, maybe not.
  4. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    As far as 5.1 is concerned, check out this thread and the links listed there. The short answer is that anyone can hear the difference between a 2-channel or ProLogic system and 5.1.
    As for 6.1 and "7.1" (the latter in quotes because there's really no such thing), reasonable minds could, and do, disagree. If you do a search on "6.1" and "7.1", you'll find a lot of relevant discussion.
    M.
  5. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Also, check out our PRIMER AND FAQ (link is in my signature)-- it might have some insight for you.
    -Vince
  6. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    5.1 is very nice. Whether 6.1 and "7.1" are nice have more to do with your room and sensibilities than simply the number of speakers. I am perfectly happy with the intended recorded format, so I like 5.1 and am not interested in much else.
  7. Willy burz
    Willy burz Stunt Coordinator
    Jun 7, 2002
    104
    I'm running a 6.1 setup with my Denon AVR3801, and I CAN tell a difference with DTS ES, and Dolby EX DVD's. Believe me it is better, But... If you have a pretty small room you won't notice the difference as much. I think that's why some people say they don't hear a difference.
    I have two speakers for the rear surround hence people calling it 7.1, even though your double rears are producing the same signal. It just spreads it out better.
    I personally won't go back to just a 5.1 setup, I love the Discreet DTS ES [​IMG] and even the Dolby EX. Plus with a good receiver you can run a matrix signal to the rears on any dvd.
    [​IMG]
  8. Jeff Kohn
    Jeff Kohn Supporting Actor
    Dec 29, 2001
    680
    I think it also makes more difference for people using direct-radiating surrounds. Dipolar surrounds just wouldn't work very well in my living room, so I'm using direct-radiating surrounds. Now that I've moved to 6.1 the surround-soundstage is more complete and enveloping.
  9. Jeff Engel
    Jeff Engel Stunt Coordinator
    Feb 13, 2002
    205
    I think most people who say you don't need 6.1 or 7.1 are those that do not have 6.1 and most have never heard more than 5.1. I have a 7.1 and the difference from when I moved from 5.1 was astounding. There is a greater sense of acutaly being IN the scene as opposed to WATCHING the scene. Imagine if you went to a live concert or sporting event and you were in the last row with all the sound from the crowd in front of you and to your sides. Sure it's ok, but now imagine you are 5 rows from the front, in the center, and you can hear the crowd all around and behind you. You are now part of the experience as opposed to being a spectator. This is how I think of the difference between 5.1,6.1 and 7.1. I can't even think of going back to 'just' a 5.1 setup. None of this is meant to knock those who have 5.1 and like it or those that can't get more speakers for lack of room design, but to say that 6 and 7.1 is not much better than 5.1 is a gross injustice to the format.
    Just my .02 cents.
  10. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
    I've got THX and a 7.1 system and wouldn't have it anyother way. I say go big or go home!
  11. Steve K.H.
    Steve K.H. Supporting Actor
    Jan 11, 2002
    719
    Think of it this way...
    2.1 opens up the front
    3.1 Starts to make it move
    5.1 Makes it run around you
    6.1 (with single or dual rears) and with
    7.1 A Wave of Sound (it fills in the top)
    There is no 7.1? Harman International and a couple of new flicks (how many now, 20?) would place a bet on that one.[​IMG]
  12. Michael Reuben
    Feb 12, 1998
    21,763
    3
  13. Phil Mays
    Phil Mays Second Unit
    May 20, 2002
    361
    I enjoy Neo-6 and on the rare occasion hear something out of that speaker. However when I do it is really entertaining. I have just purchesed a 5 channel amp and will use the AVs internal amp to push the 6th channel. If I am not mistaken I think in home theater the 7th channel is split from the 6th channel. I guess if you had a large enough room with Neo-6 you could hear a difference with 7.1....of course I have the bug and am work toward the 7.1.
    As far as a real difference goes though I think the 5.1 set-up is the most significant and if money is an issue then I would spend what is available on a better 5.1 rather than spreading it across 1 or 2 additional speakers.
    Just my 3 cents.
    Phil
  14. Dave_Olds
    Dave_Olds Stunt Coordinator
    Apr 24, 2002
    188
  15. rodney wiley
    rodney wiley Second Unit
    Nov 23, 2001
    307
    When I switched from pro logic to 5.1 I thought God had blessed me with new ears!!! The difference even with a mediocre receiver was unbelievable! Now that I have switched to 6.1 and 7.1 the difference is still very noticeable but not a must have. YES by all means make the jump to 5.1
  16. Michael Lomker
    Michael Lomker Stunt Coordinator
    May 17, 2002
    164
    I think 6.1 and 7.1 make a lot of sense for a dedicated HT room. In a dual-use room there are just too many speakers involved. If you are buying a new receiver then I'd definitely chose one that gives you the option to upgrade.
  17. Mike Veroukis
    Mike Veroukis Second Unit
    May 8, 2001
    455
    Canada
    Michael
    If you're gonna talk about all these psuedo surround modes, don't forget Yamaha's "8.1" which incorporates two front "effects" channels. No idea what that sounds like but I've heard good things about it. Seems strange though.
    - Mike
  18. Mike Strassburg
    Mike Strassburg Second Unit
    Nov 4, 2001
    421
    Brad,
    Just an "average Joe" or average Mike throwing in his two cents.
    I finally got tired of my old Pioneer receiver with 2 fronts/2 rears set-up. Bought a 3802 with 7.1 capability. Used it as 5.1 and was amazed at the difference. After a few months I decided to take a cheap pair of KLF monitors (I'm talking $20 for the pair) and put them in back for 7.1. Had the in-laws over for JPIII and we ALL were stunned at the 360 degree sound as it felt like we were IN the movie vs watching it.
    I would say at least demo a few 6.1/7.1 set-ups before making a decision & then decide if your ears like it enough to spend the extra $$$. If the $$$ isn't that much more I'd hate not to get it and have "buyer's remorse" in a very short time. Good luck...Mike
  19. Craig_Kg
    Craig_Kg Supporting Actor
    Feb 25, 2002
    768
  20. Jerome Grate
    Jerome Grate Cinematographer
    May 23, 1999
    2,984
    6
    110
    I think it is, most mid end receivers are coming with it I have a psuedo set up with using a second DPL receiver coming from the surround pre-outs of the Harmon Kardon, and I find it quite good. I demonstrated T2 and Pitch Black for some friends both DTS-ES and they were able to tell the difference with the rear center channel. Just don't stop there either, I use with Logic 7 on all two channel applications (dolby pro-logic, stereo) and it works. Not only the surrounds are in stereo by using an algorithim to channel sound from the left and right front channel to corresponding surrounds but, any sound that would appear in both surrounds are sent to the rear center channel. So defintely worth it, it creates a fulling soundstage, and for me I get the "Wow, look at the speakers". See my pixs for the set up on my signature.
