4ohm reciever, 8 ohm speakers
Discussion in 'Speakers & Subwoofers' started by Steve BL, Jan 3, 2006.
  1. Steve BL
    Steve BL Auditioning
    Jan 2, 2006
    9
    I recently bought a new HDTV, from a local retail store and they tossed in a new cheap 5.1 home theaters system (RCA 2620) that I have not used yet and was thinking about selling. BUT my old HK receiver just went for a crap so I decided to try the RCA out until I can afford another good quality receiver.
    My problem is the new RCA uses bookshelf type front LEFT, RIGHT and CENTER channel speakers that are 4ohms and 8 ohms rear surrounds.
    My old receiver was pushing a set of 8ohm JBL towers and center speaker as well as 8 ohm surrounds
    My questions are...
    Will it hurt the receiver or speakers if I use my 8ohm JBL speakers with the RCA receiver and not the 4 ohm speakers the receiver came with.
    If it will work what are the pros and cons.
    Thanks for any help
  2. Alan Pummill
    Alan Pummill Screenwriter
    Jul 6, 1999
    1,262
    The 8ohm speakers will be an easier load on the unit than the 4ohm speakers would have been. I don't think you should have any problem!
  3. Steve BL
    Jan 2, 2006
    9
