Nevakonaza
- Nov 2, 2011
- Shane Johnson
Good morning
Been thinking about getting a 4k Bluray player for a while now to go with my QLED Samsung QE55Q6FAM.
Not really after a high end one, doesn't even have to have smart features I don't see the point in YouTube etc on a player when it's built into the TV anyway, so a standard 4k bluray player should do, my max budget I'd spend up to £140.
i think the only requirement is HDR10..as I'm sure my TV supports this.
I'm currently using xbox one for a bluray player which is fine but I'd like a dedicated player
Appreciate the suggestions (if any)
Cheers
Cheers
