John DeSantis
- Nov 18, 1999
How are you 4805 Owners shutting down your PJ? The Manual says you can just flip off the Unit's Power switch or use the Remote. But using the remote still requires you to flip off the Power button, so what's the point of using the remote?
I did finally wire in a Switch to the outlet it's plugged in to. (wife couldn't reach the switch on the unit) Just seems like the remote should be able to power it completely off.
