4805 projector mounts on ebay?
Discussion in 'Displays' started by Mike Ki, Jan 14, 2005.
  1. Mike Ki
    Mike Ki Agent
    Nov 4, 2004
    49
    Has anyone bought any of these mounts on ebay? Were you inpressed with it or have any problems with it? Would you recommend it to others? What seller did you buy it from (there are a few) and have any conflicts with them?
    Any info. would be great.
    Thanks Mike
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Mike, I don't know anything about those mounts. But I built a ceiling mount for my X1 for about $15.00, and it is very easy to do. If you go to Avsforum.com, do a search for Monkey_Man's mount in the Under $3500 Projector section. Instead of plexiglass I used scrap MDF, and I deleted the springs.
