4802 Owners
Discussion in 'Archived Threads 2001-2004' started by Thomas P., Jan 12, 2003.
  1. Thomas P.
    Thomas P. Stunt Coordinator
    May 20, 2002
    123
    Hi everybody...I hooked up an HD tuner and a DVD player to the component video in on the 4802, and the s video out to the monitor but no OSD. I have triple checked everything and it is hooked up right. Any suggestions? Thanks.
  2. Thomas P.
    May 20, 2002
    123
    Well, I found a solution. I ran a coaxial out from the Denon to the monitor in and it worked I have OSD. I'd still be interested as to why it stopped working, though.
  3. Ammon
    Ammon Stunt Coordinator
    Aug 26, 2002
    129
    If the only thing going out to the monitor was the single s-video, that may be the problem. I have the 4802 and I do know that it does not do video up-conversion like the 5803 or 3803. However, I don't think either of them do any sort of down-conversion (component to s-video signal). But I may be wrong. I currently have hooked up my DVD and Xbox to the receiver and a component out to the monitor (Input 3) as well as an s-video out to the monitor (Input 1). I have my DirecTV going through S-video so I switch my TV to Input 1 for watching DirecTv and from there I can get the OSD. I would hook the monitor out of the receiver with component and also have an s-video going to your monitor. Hope that helps!
  4. Thomas P.
    May 20, 2002
    123
    Thanks.
  5. David Ortiz
    David Ortiz Auditioning
    May 21, 2002
    10
    Thomas,
    You might check if you had the s-video cable connected to Monitor-2. O.S.D. is only output through Monitor-1.
    David
  6. Thomas P.
    May 20, 2002
    123
    Thanks David. I did that to no avail. I deduced it must be the Sony. Called Sony CS and they sais it must be defective. I lugged the darn thing back to the store and exchanged it...voila, still no s video display. I'm baffled. I called and arranged for tech to come out. I now have the moving vertical white band problem, too.
