47" Panny widescreen bars
Discussion in 'Archived Threads 2001-2004' started by Rick Simpson, Oct 15, 2001.
  1. Rick Simpson
    Rick Simpson Agent
    Aug 15, 2001
    25
    On my panny when i watch a widescreen, the bar on the top is a 1/2 smaller than the one on the bottom,how can i fix this?Thanks
  2. Carlo Medina
    Carlo Medina Executive Producer
    Oct 31, 1997
    10,451
    652
    It's more difficult than you think because there is no Vertical Position value in the service menu. There's vertical correction, S correction, vertical height and some other stuff, but no vertical position. I'd go to http://63.249.150.205/panny/ and ask there. That's Brett's really helpful site on the PT-47 TVs.
  3. Rick Simpson
    Rick Simpson Agent
    Aug 15, 2001
    25
    Carlo,It was pretty easy to fix,thanks to JohnnyG.I changed
    the "VLIN"parameter in the service menu and now it is perfect.It was out 1/2".Now I still have an original prob that has been there since I got the set, the bottom bar rounds up in the center from both ends ,not bad but would like to fix it .It's out a big 1/8"Any idea's Carlos.Thanks
