42" Plasma Panasonic HD vs non-HD?
Discussion in 'Displays' started by Ning Wong, Apr 28, 2004.
  1. Ning Wong
    Ning Wong Stunt Coordinator
    Jun 27, 1999
    248
    I am really looking at the panasonic 42" plasmas right now.
    is it worth it to purchase the HD version over the non-HD version?
    The difference in price won't absolutely kill me, but i guess i'm looking for the best bang for my buck.
    Also, do you guys think this 42" is the best way to go?
    Thanks!
  2. Danny Beck
    Danny Beck Stunt Coordinator
    Jan 14, 2004
    164
    I have been very impressed with the ED Panasonic plasmas. Yeah, the HD models do look better but from a normal viewing distance the ED models really do impress.
    It really comes down to money for you in the end. Whats the most you're willing to spend. If your budget only allows you to buy the ED set than go for it and be happy with it. It's a great tv. If you can afford the HD model though than go for that. At a normal viewing distance of 8-10 feet though the differences won't be massive. Panasonic seems to be making the best consumer plasmas right now.
  3. Ning Wong
    Jun 27, 1999
    248
    as i research more and more, it seems ED is the way to go.
    but what about size?
    42 or 50?
    my viewing distance is about 9-11 feet...we're going to put it above the fireplace
    thx!
  4. Mort Corey
    Mort Corey Supporting Actor
    Nov 21, 2003
    981
    Go for the 50" unit. It'll also aliviate the need to decide between ED and HD (they're all HD)
    Mort
  5. Danny Beck
    Jan 14, 2004
    164
    Yeah, at 10 feet or more the 50" is the best option.
  6. dan fritzen
    dan fritzen Second Unit
    Mar 19, 2001
    304
    Is that safe?
  7. Ning Wong
    Jun 27, 1999
    248
    yes it's safe
    the fireplace is one of those gas ones w/the fake logs.
    JUST for looks
