40H80 locks or not?
Discussion in 'Archived Threads 2001-2004' started by Corey Albers, Aug 6, 2002.
  1. Corey Albers
    Corey Albers Agent
    Nov 14, 2000
    25
    sorry for the post.. i'm sure it's been discussed to death but i couldn't find a straight answer searching the archives...
    does the 40H80 lock with a progressive signal? i'm debating between the RP82 and RP91, and would like to scale non-anamorphic discs...
    thanks
  2. Elliott Willschick
    Elliott Willschick Second Unit
    Dec 1, 1998
    333
    The 40H80 does not lock into full for progressive scan. I believe I have read that the scaling for the RP91 still looks better than tw2 mode and a non-scaling player but at least you have a choice.
  3. Juan_R
    Juan_R Supporting Actor
    Sep 4, 2001
    683
    Corey is correct on both. The H80 does not lock and the scaling of the RP-91 is better than using the H80's theater wide modes. I have compared the scaling of the RP-91 with the one on my Tosh 65HX81 and the RP-91 beats it hands down.
    By the way I don't think the RP-82 is capable of scaling, so if you go with that player you would have to use the TV's theater wide modes.
