JoeRiley
- Jan 9, 2003
Hi, I would like to get a new Widescreen HDTV that's over 40" (46-48, preferrably)... but don't want to go over $2,000 (would go slightly over though). Is there anything out there with DVI-Inputs?
Also, what's the difference between HD-Component Inputs and normal component inputs?
I've spent hours on sites like Bestbuy.com and Tweeter.com trying to find some, with little luck. Are there any other good sites to check on?
Thanks!
-Joe
Thanks!
-Joe
