George Caronan
- Nov 25, 2003
Hello everyone. General question that I had a need to ask. Say you have a five channel amp and you are using only four out of the five, given the fact that one channel is not active will it result in better efficiency/headroom for the remaining active channels? I've read in various places that this is indeed the case. In a receiver where you are only able to use five out the seven amps available will the same principle apply? Is it because one or two amps less used helps the strain for the transformer/power supply providing cleaner, higher output? Looking forward to opinions and answers. Cheers!
