4 ohm speakers and a Receiver ( 6 - 16 ohms) - Should I be worried ?
Discussion in 'Archived Threads 2001-2004' started by Samson, Nov 17, 2001.
  1. Samson
    Samson Stunt Coordinator
    May 15, 2001
    76
    I just recently purchased a Bohlender Graebner Radia X1 center channel which is rated at 93 db sensitivity and 4 ohms impedance. My Pioneer Elite VSX - 33TX recommends speakers rated at 6 - 16 ohms. My mains are Def Tech BP10's.
    Should I be worried about this combination this setup considering the impedance of my center channel ? Will this affect the reliability of my receiver ?
  2. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,861
    543
    9,110
    If you play it loud enough, you just run the risk of causing the speaker to draw a bit more current than what the receiver was designed to supply your center channel speakers.
    But for "normal" HT use, you should be okay. But if you get the "Protector" error message from your receiver, back off the overall volume on the receiver, you've reached the limits for the receiver's amps to provide enough current to produce the SPLs demanded by the overall volume levels.
    PatCave; HT Pix; Gear; DIY Mains; DIY CC; Sunosub I + II + III; DVDs; LDs
