4 ohm or 8 ohm
Discussion in 'Archived Threads 2001-2004' started by Vincent_S, Jan 10, 2003.
  1. Vincent_S
    Vincent_S Second Unit
    Nov 29, 2002
    450
    Which causes the reciever to work harder? I think 4 but can't remember.
  2. Jerry St.Marie
    Mar 12, 1999
    41
    You're right.
  3. Phil Dally
    Phil Dally Stunt Coordinator
    Jan 9, 2003
    121
    What would the difference be? I mean what do you mean "work harder"?
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    An 8 ohm load is easier for an amp to drive than a 4 ohm load.
  5. Cees Alons
    Cees Alons Moderator
    Jul 31, 1997
    19,474
    340
    9,110
    Cees Alons
    Yes, a 4 Ohms driver will draw more current at the same output voltage from the amplifier than a 8 Ohms driver.
    But that's only part of the story. The amplifier is optimized for one of the two, although it will often allow both (preferably through a switch).
    If possible, choose the impedance given in the technical specs of your amplifier for optimal results.
    Cees
